1 - 11 of 11 Posts
So, with the Cummins running, when you take the cap off, turn it over and place it over the hole . Does the amount of blow-by, blow the cap off the hole??
2006 Dodge cummins 5.9 6 speed
ya i just did a oil change and it is still perfect. I bought the truck for $1,500 the guy that i bought it from said it had broken injectors, so i was gonna put a brand new engine in it but i looked at the injectors first and they were 2 bad injectors so i replaced the and it runs great. My dad has a identical truck and his has no blow by and he drove mine and said it had way more power, so that is why i am confused they are both stock
If you are fine still driving it, I would drain 2quarts of oil out and then throw 2 quarts of hotshot stiction eliminator in it. Maybe your rings are very caked up. ✌
· TECH SPECIALIST
Follow vaders advice and re-evaluate after 1000 or so miles...
1 - 11 of 11 Posts
