1 - 4 of 4 Posts
Installed a nice billet aluminum tappet cover because I was leaking out of the gasket, decided to go big or go home and buy a high quality cover. I’ve recently started running more boost and fuel. I am leaking out of the vents in the tappet cover. What would be causing this? Could I make some sort of line to feed back into the engine? I think it is because of more blow by, but what do I know. I work on cars not deisels
1998 Dodge Ram 2500 12 valve Cummins
#0 fuel plate
Boost elbow
3k governer springs
Rack cap
5 speed manual
Which tappet cover did you install?
‘98 2500 Quad cab 12 valve 4x4 with 5 speed
I’ve heard of ppl installing the valve cover breathers from a Case/IH Cummins to account for the leaks that can occur from the billet tappet cover vents
A lot of those billet tappet covers don't have a baffled vent. If yours is one of those, that could explain it. You could always rig a catch-can.
1 - 4 of 4 Posts
