1 - 9 of 9 Posts
How do I block the wastegate on my 02 all I see is a black metal line
Sent from my LG-P925 using AutoGuide.com App
Discussion Starter · #2 ·
bump need this done egts too high
im not sure its on an auto if that helps i will look tomorrow
i just got a pair of vice grips and pinched the metal wastegate tube flat and that did it. problem solved, didnt even need the j hook. plus the hy's max boost is 25 anywho so no worries...
· Vendor
So instead of doing it right you ruined the waste gate actuator? And efficient boost is maxed out around 35 psi....
Sent from my DROID RAZR using Tapatalk
yup, cheaper too...:hehe:
1 - 9 of 9 Posts
