41 - 47 of 47 Posts
The 2019 3500s DRW with air assist has 4 leafs.
The 2019 3500s DRW without air has 7 leafs.
US ARMY Retired
Not sure about previous YM trucks...but my 2019 Ram 3500 SRW with rear factory air has 4 factory metal leaf springs to the front of the axle and 3 to the rear of the axle. Its like the extra one to the front is a half spring. All of my previous Ram trucks had leaf springs....except my 2017 Ram 2500 had the coil springs.
Also my 2019 3500 SRW has 3:73s with the 12" rear axle....according to the equipment listing.
Just got my truck back from the dealer to have the bag replaced. I had 2394lbs of payload. Crazy there is a record of how much the truck is hauling.
Modern vehicles keep track of many values, so why not that peak pressure?
US ARMY Retired
Was that over you Max payload according to your door sticker?
It is over my max payload door sticker of 2186lbs. But at the 2394lbs, I did not have the light saying I was over weight. The bag was replaced under warranty (it should not have blown apart at the weight I was at). I am not sure at what exact weight the air system says it can't level the load, but I would think it is most likely at the rear axle weight limit (which would be ~3000lbs of payload).
Reactions: Cummins0867
41 - 47 of 47 Posts
