1 - 3 of 3 Posts
I just did all the deletes, and i didnt block the port that usually is i just took a hose from the the EGR pipe in the front and ran a 18" line to the head.
Should i bleed it? If so what is the correct procedure? Ive been driving the truck alot since and havent noticed any problems
I have the same question. I know that coolant vent pipe says to open during coolant fill. Im not sure if opening just a small portion like removing a hose would matter. Do I open that vent with the engine running or will it bleed off that small amount of air on its own?
I would not worry about it. As long as you have let it circulate and have toped it off you will be fine. Make sure your recovery bottle is at a good level and drive it,you will notice it will burp the last bit of air on its own and the level in the bottle will drop just a bit.
1 - 3 of 3 Posts
