1 - 13 of 13 Posts
well ijust installed the black maxx with the custompillar mount and this thing is awesome ! i had to drill and tap pre turbo for the pyro meter that wasnt to bad i had to use a small cordless drill becaues of the room and had to cut the dill bit in half, ran the wires and by the way the quality of h&s stuff is top notch. i can keep an eye on my boost, egt, tranny temp, i can go on and on but the black maxx is worth the $, now i have to wait till the weather clears ( 17 deg and snowin )so i can install the 5" s/s exhaust w dpf delete that i got from them, cant wait:party018:
The perils of getting a new truck... I have heard rumours of tuners being released for 09.5 + up trucks this spring. Time will tell I guess. Or you could get a PMT since they supposedly already have it figured out! Ha, ya right!
Reactions: kaczenski
To the OP, are you running around with the DPF intact now, or are you replacing a delete pipe with TBE?
I was wondering the same thing. I'm pretty sure you can jack stuff up pretty bad running h&s with the dpf still on it.
...now i have to wait till the weather clears ( 17 deg and snowin )so i can install the 5" s/s exhaust w dpf delete that i got from them, cant wait:party018:
? This is what had me wondering....???
Discussion Starter · #11 ·
no i still have the dpf but i have my tuner on stock till i can change the exhaust the weather hasent been all that great to crawl up under it to change the exhaust i put all that on my sig caues when i got all the goodies thought i was going to be able to get it all done but i dont. it sopped snowing lastnight so i am going to go out here and do the egr cooler delete. i think i have enough time
i don't think it matters what power level you're on, just having it downloaded will cause problems with you're dpf i think.
Discussion Starter · #13 ·
No No Probs W/ The Dpf Still On ,though I Wouldnt Recommend It , Just Finished The Egr Cooler Delete Man What A Pain In The @ss Glad It Is Done It Is Like Getting A Tattoo On Your Elbows You Are Glad You Only Have 2. Well My Next Step Is Exhaust And I Should Be Complete
1 - 13 of 13 Posts
