1 - 4 of 4 Posts
I read in the june issue of Diesel Power Mag that bio diesel should not be used in anything other than a truck that has a mechanical pump. basically meaning 98 and down right? Well my cousin and I planned to make some but once we read this we figured we better make sure. So what is it guys? Bad, good or none of the above?
BTW, his is an 06 and mine is an 04.
he got the "600" I just have the HO
Hmmm...I have run B20 in my 04.5 Common Rail and it did just fine. Watch the fuel filter and other then that your good.
on my 2005 it says you can run B5, ive heard the reason they don’t recommend running more than 5% mix is because of the water separation limits on the stock fuel system
Whats your honest opinion on fuel prices fella's? Thinks they are going to keep sky rocketing or stay where they are at or fall down alittle?
1 - 4 of 4 Posts
