1 - 9 of 9 Posts
Hey guys for the last little while when in 4wd it binds like crazy someone suggested that my axle was stripped but thought id ask if anyone has had experience with this issue.
My truck does it too. I think they all do
binding as in when turning sharp? if so mine does it too, most of my 4x4s did when i had them
4wd on pavement or a surface where the tries are not able to have some slip/spin will do this and you will end up ruining your t-case.
no this is happening in snow could it be a bad axle u joint
Is it when ur turning?
no going straight ahead its almost like a popping sound
It could be ur axel u joint or drive shaft u joint. Jack the front end up and turn ur wheel back and forth and if u hear a noise most likely it's ur driveshaft u joint. Then go to front wheels and turn the tire front and backwards with ur hands and if it's a bad axel u joint u will hear it.
Discussion Starter · #9 ·
ok thanks for the help its most likly my axle joint since my drive shafts just got rebuilt
1 - 9 of 9 Posts
