biggest tire size 01 3500 stock 16"
2546 Views 18 Replies 8 Participants Last post by  ryans01
i'm tired of the crappy little ol 235/85 tires, and was wanting to go bigger, i know that with the 17's i'd have a bigger selection, but with the dang metric tire sizes i don't have a clue, i'm wanting what would equal out to be something like a 33 x 10.5 or something close to it. would a 265/75 be close??
not wanting a mud tire, alterrain or street tread only...
and i'm not going to go with the newer 17's either, hate the prices and selection
thanks
1 - 19 of 19 Posts
I have 285/75R16 on mine but i had to use a spacer in the back between the tires. A 255/85R16 will fit without a spacer. i think it is something like a 33-10 and a 285/75 is a 33-11.5
what size spacer did you use?
2" spacer 315X75r16 (35x12.5) Makes the rear tires stick out bad. Like 3". Unsafe without flares, and no flares available for the duallie, I don't think. I use those horribly ugly rubber flexy flares.
If you are not concerned enough about traction to go mud tires I would suggest pizza cutters. Then you can fit 'em without a spacer and you won't need the flares. 255x85r16's are about 33.5" tall and about 10.5" wide. I think they would clear just fine.
i'm not worried about the traction, i've got 6 dang near slick tires and i still go anywhere i need to...people just need to learn that if you spin the tire fast enough you might just get through it...
i was looking at the 255/85s and will probably go with them
i hate how dodge puts a 4" lift on the trucks and puts such a small sissy tire on...i hate having 2' of open space between the fender and the tire...just wanted to get a tire that would fill the fenderwell a little better.
thanks for the help.
I used a 2in spacer. Rear tires stick out about 1.5 or 2in not to bad
Discussion Starter · #9 ·
what brand/where would be the best place to get one?
I can't remember where i got mine. Look in the back of diesel power and there will be a add in there for a place that sells them. I may have mine for sell here soon if you want them. I'm making my truck into a SRW. So if i like it i will be selling the bed and front and back spacer. Let me know
Discussion Starter · #11 ·
it's gonna be sometime after the first of the yr before i'm ready to get some new tires....i might just save my pennies and get a set of bolt on 19.5s and run them....
i might just run the 255's still undecided...ya know...depends on $$$ and tread...thanks though for the info.
I ran 305 BFG all terrains on mine stock height before i lifted it. They fit great and looked way better
Discussion Starter · #13 ·
Discussion Starter · #15 ·
255/85/16 Cooper discoverer st's, tall and narrow so no spacer is required I believe they are 33-34" tall and 7-8" wide, I ran them on my 01 3500 and loved them.
:thumbsup what kind of mileage did you get out of them?
Discussion Starter · #17 ·
I believe like the 285 and 305 sizes are about 33" tall
the reason why i had the ??? about the 305s is well all the 305's i've used on my other trucks are 305/75/r16s so that's like 33X12.5X16 to wide for me...
just put 315/75/16 pro comp all terrains on last night, also had to use a 2" spacer in the back. truck looks bad a$$ imo. if ya want ill try takin some pics n puttin them up. was runnin the 22.5 kit with a 2" levelin kit, those tires are about 36" tall but kinda skinny. so now my 315's are 34.49 tall. looks good im happy plus a 50k mile warranty with tires.... hopefull i know some tire co are anal about warranty tires.-scott
Discussion Starter · #19 ·
yeah i'd like to see some pics of them...
1 - 19 of 19 Posts
