1 - 20 of 20 Posts
I was wondering if anyone knows what the biggest tire you can put on a 06 3500 DRW with a 2" leveling kit. I would like to put 33 inch tires on my truck but don't know what size spacer I need.
· On call 24/7
I had 285/75/17 nitto terra grappler on my 2005
I have toyo trail grapplers 35x12.5x17 with a 1/4" on the inside and 2"between and they work with no issues
I'm running the same setup in a toyo mt. No problems but I'm also running adj control arms and track bar.
I have a 05 drw and it has 235 80 17 are there any taller tire I can get without lift kit or leveling kit?
· On call 24/7
· On call 24/7
I'm 99% sure that 255/80/17 will work without spacers.
Okay I tried to get the 255 80 17 but I ant cause they say my rim is 6 wide and they need a 6.50 inch rim cause if not they will blow out could I get some Advice cause I hate the smaller rims but don't want to have to buy rims and tires
· On call 24/7
Find a different tire shop. The early 2nd gens had a different offset and will not allow 255/85/16 without a spacer.
I have a 05 one ton and I've called 8 shops around me and everyone says they will sell me tires but refuse to put them on my rims cause there will be to great of a chance for the tire to blow out and it being there responsible. Cause I hate the idea of buying small tires for more money.
1 - 20 of 20 Posts
