1 - 10 of 10 Posts
Ok i think i'm gonna do a 98 style 12 valve do everything to it pump turned way up, fire rings head studs, twin turbo ... Can i still run straight WVO? do you think it will hurt anything or get heated fast enough as i will be pushing it through the motor? Will i make alot less power and what do you think about this? Also what is the best system to put on the truck like this? and is there an easy way to make one that will work?
If it smokes on diesel it will coke the engine WVO. Not good on the engine
well with any kind of pump work a 12 valve will smoke on diesel... so r u saying wvo is only good on a completely stock truck?
and what is happening when you say coke the engine?
Rescue Tower
I have never seen a WVO engine last long term.
my dad's p stroker has been runnin on it a LONG time and has 276000 miles probably 70000 miles at least
but i know with having a LOT of black smoke i could have a problem with it coking or just take down the engine life by some just not sure how long it would last
Rescue Tower
Then why are you asking us questions? Seems you have it all covered...
Discussion Starter · #10 ·
o your QUITE mistaken if you think I have it all covered. idk if anyone else had any experience in the field of power my dads did not have power upgrades
1 - 10 of 10 Posts
