does it really pay to buy a full cold air intake or just put a BHAF on it and call it quits and save a bundle
Depends on your power modifications. Paper disposable BHAF filters flow well, but as power levels increase they won't flow enough for modified trucks. Also they are expensive to replace at $60+ a crack. Also, since they're paper, you want to run an Outerwears wrap or make a shield for it to prevent the paper from disintegrating due to moisture (driving in the rain behind other cars and taking a lot of moisture into the engine area for instance).
-Chuck
:thumbsup:like i said... $230 for a plastic tube and a cone filter
might as well go to the muffler shop, find a chunk of 4" pipe and toss a filter on the end of it... max cost about 80 bux.... OR
just keep the stock tube, cuz it's fine... and buy a filter for the end of it...
why donate cash to the K&N cause ?
To each his own I guess, I am interested in the whillys whistler though, those are freakin LOUDBig paper elements in all the CAT's on the Drilling Rigs
works for them, works for me
That means nothing.Big paper elements in all the CAT's on the Drilling Rigs
:ditto: :agree2:That means nothing.
The big difference is those Cats are stationary engines, not bouncing around in a vehicle though puddles or a foot of snow.
supposedly the stock airbox is good to 500HP
i like the way that looks
i like the way that looksarty018: and do u just run the stock filter or something that flows a little more air like a KN ??:thumbsup:
If you have the hp and need more air than a paper filter will flow you need a freer flowing filter.i like the way that looksarty018: and do u just run the stock filter or something that flows a little more air like a KN ??:thumbsup:
HAHAHA :hehe:If you have the hp and need more air than a paper filter will flow you need a freer flowing filter.
Your filter minder will tell you if the filter is new and still sucks into the red.
I use an AFE but a Amsoil or K&N would work too.
I have nothing against K&N like some folks do.
In fact I have more dislike of BHAFs after seeing a couple of them popped off the hose without the owners knowledge for who knows how long.
