Might be needing both shortly..:woot:
Discussion Starter #2
Turns out it was only the map sensor...
So what does a map sensor do and what are the systoms of one going bad if I may ask ?
I had one(MAP sensor) go bad, It threw some codes and alight the Check Engine Light. The MAP sensor then decided to throw my truck into DE-FUEL MODE!
my MAP did not go bad.. I had installed a XZT+ on MOnday and where you plug the MAP into the quadzilla harness had come loose as I was driving.. it gave me a dead pedal and I had zero boost.. It seemed like a VP44 failure while I was driving..
