1 - 19 of 19 Posts
im looking for a place to buy a locker or lsd from ?
Ok. But who sells it the cheapest?
TECH SPECIALIST
If you are going to do the install yourself, I would go with a retailer that has experience installing differentials and gears. I purchased mine from Just Differentials and they were always right there with advice and encouragement throughout the install.
If you are having it done by a shop, ask around about the shop's reputation and speak with the technician that will be doing the install. Ask them a few questions about pinion bearing preload/carrier bearing preload and how they check it(it is done by taking a rotational torque reading) If they seem like they have a good handle on the install and charge a reasonable price then give them a try.
One last word of advice, go with the installer that KNOWS what he is doing; do not go with the installer who DOESN'T KNOW what he is doing that will undercut the first guy's price and be $100 less. It will be the most expensive $100 that you ever saved.
Check your local offroad shops. They will be the more familiar with installing lockers, especially an air locker. I have ARB's in my offroad rig and love them. They are pricey but worth every penny.
ARB RD51, air. I don't think you'd want anything less on the front, you would definitely only want a selectable locker.
Unless you have a lot of weight on the rear, doing the front first will give you more traction, close to 1500# more on the front axle vs an empty truck's rear axle. This is assuming you don't need to turn and move forward at the same time.
I emailed the folks at the site I posted above, they replied within 24 hours confirming they have the RD51 in stock and ready to ship but I have not done business with them yet. Make sure you get the upgraded heavy duty air line too.
Reactions: rbisch
Which one are you going to use for the front axle. Limited slip, locker, air,electric ?
I'd use an Eaton E-locker. It's a selectable, it's cheaper than the ARB and quality wise, just as good. That being said, if you want "on board air" on your rig then I would think about the ARB. The main cost difference (About $300.00)between the Eaton and the ARB is the Air Compressor.
Anyone know the eaton e locker part number??? Cant find it for the Dodge 11.5"....
Eaton doesn't make an Elocker for the rear, only the front 9.25" and the part number for that is 19622-010 if you have the 33 spline axles, which as far as I know is the spline count used on the 2002-2010 Dodge Ram 2500-3500 front diffs.
Discussion Starter #14
so
then a good combo would be an eaton up front and an arb out back ?
MOD-A-HAULIC
I have a Yukon Locker for the rear.. Got it from Larrys Ring and Pinion...
Good prices there..
They also have e-lockers for the front.
I believe the Power Wagon front locker fits, get number from dealer. Read somewhere the Eaton requires a bit of grinding inside case.
TECH SPECIALIST
The Eaton E Locker requires grinding the differential housing to get it to fit. Since grinding weakens the housing, you may want to reconsider that particular option.
Ring and Pinion has the electric front locker from Mopar for the power wagon. It is 887.01. List it as compatible for all 9.25 diffs.
1 - 19 of 19 Posts
