I bought a 3 hole pillar pod, also a pyrometer, boost, and transmission temp gauges. I plan on drilling and tapping a hole in the exhaust housing just before the down pipe. The boost says install in any vacuum line? or drill the intake for a fitting but im not sure which vacuum line or where on the intake is best, any one with a good idea?
temp guage
drill yor hole in the exhaust manifold before the turbo.
Take a look. Good instruction on probe install.
Gauge Install
All Installed
The boost hookup was simple, the pyrometer is now installed before the turbo, a easy job once the turbo is removed, the transmission temp was very easy. I put it in the 47Rh cooler line where the stock sensor was, used a 3/8 NPT to 1/8 NPT bushing for the new sensor, then used a 1000 ohm 1/2 watt resistor to jumper the old wires, the transmission shifts fine, cold or hot. Thanks Guys!!!
