1 - 20 of 63 Posts
Cummins Fanatic
Just installed the BHAF on my truck. Smokes a little less, little better throttle response, and can notice a faster spool-up. Best 40 bucks I ever spent. WAY better airflow than the stock airbox with the K&N! Truck sounds much healthier too! Anyone else runnin one of these?
will be soon. I allready have the pvc elbow just need to buy the filter.
Cummins Fanatic
Hmmmm, I must be the only guy on here to do this mod:w:
I might just have one on my 3rd gen....... 46 bucks finished and wow does it get alot of air in
Cummins Fanatic
Nice Signature.....Sneaky:lol3:
Done it here too!!! I love it!!
I would also suggest getting an Outerwears Prefilter. It will let your filter last longer and it is water resistant.
Tech Specialist
x2 on the BHAF!!! It's one of the easiest upgrades anyone can make without breaking the bank and it sure beats the stock setup no matter what type of aftermarket drop-in filter that may be in it. For those 2nd genners out there that haven't done this mod yet, you DON'T know what you're missing! The air intake system is the most CRITICAL component when considering upgrading the horsepower on our trucks. Without substantial air flow, it really doesn't matter how many other mods you have lined up behind it, the air flow into the engine is key to what is produced down the line and put to the ground.
Got it here too. Works great. Then you take out the silencer ring and really listen to 'er whine.
Will it work on 3rd Gen specifically a 06? If so please break in down what do I need and suggestions on where to get the parts. Thanks
I wanna know, I wanns know! I have an 06' too. Someone post up how to do it and what is needed. I want to put BHAF in my sig. too. :peelout
Cummins Fanatic
Discussion Starter #13
It should work on an 06. All you need is a NAPA 2790 filter. You can also buy a heat shield (don't need it) to shield it from the turbo. Just search BHAF on this site and you should be able to find what you need! :thumbsup
What do you need and besides the filter? and what brand and part number of filter do I need.guess i was al ittle late.
Make sure you install a heat shield :thumbsup
Higher EGTs are a problem with these filters
maybe 50* or more
Thats a Biggie................
Hope I can close the hood.
Gonna get me one ASAP.
Thanks.
Get a pre filter to :thumbsup
1 - 20 of 63 Posts
