Hello everyone,
I'm planning to bite the bullet and purchase either a 2nd gen swap kit or a replacement turbo for my truck. I'm getting the bad turbo codes and long story short dealer hosed me and I'm paying for it...Below is info about my truck and goals as well as some of the options I've considered.
-Truck: 2015 ram3500 (SRW) 6.7 cummins
-Tranny: G56 with stock clutch for now
-Miles: 30K...Practically a brand new truck - cummins/ram need to pick better turbos for trucks since mines already failing at 30K miles!
-Mods: Fully deleted, tuned with MM3 tuner, 4in exhaust
-Goals: Fun truck to drive. I rarely haul but when I do its a small boat and small trailer.
-Other notes: Plan to stay on stock studs, stock fuel, and stock clutch for as long as I can. WILL upgrade when needed and will drive conservative to help keep things okay until I can upgraded other parts.
BUDGET: $3000 - The cheaper I go on a turbo setup the more money I'll have left for other mods such as injector nozzles or a clutch upgrade.
Setups I've considered:
-Smeldings 2nd gen swap kit S467.7 with billet wheel: $2,594.00 - Seems to be the cheapest 2nd gen swap. How is this kit quality?
-BD-Power S467 Rumble B Turbo Kit: $2,750.00 - Looks like a solid kit and comes with manifold and everything and is the S467 so it'll set me up for future mods.
-H&S Motorsports SX-E with 69mm wheel Turbo Kit and speed steed manifold upgrade: $3,099.00 - Looks to be a solid complete kit but not sure if its an S400 or S300 series turbo since it doesn't specify.
-Fleece FPE-351-1317 Holset VGT Cheetah: $2,699.00 - Keeps stock functionality but is a VGT turbo so I'm scared it'll fail again as well as be too small.
-BD Diesel Iron Horn Kit S369SXE/80 1.00AR: $1700 - Cheapest of all options but scared it'll be too small and limit me in the long run. IF I went this option I'd have a little bit of budget for other mods.
I would consider a complete Fleece kit but the price is very high with manifold, turbo and coolant tank and out of budget.
Any advice? Thanks ahead of time!
