1 - 11 of 11 Posts
Ok my buddy got my cummins off of me. He wanted to know if this set-up would work or why not?
HRVP-44
Smarty
Quadzilla Commander gauges
120HP injectors
Airdog 150
It's already got a VB Deep trans pan intake and a 5" exhaust.
will this work good and how much smoke?
I wanna go fast...
If you are going with the Commander, I would just go with the Adrenaline withthe Pulse monitor. It is the same as the commander, and a lot of people seem to be happy with the Adr. I would Airdog, Injectors, and Adrenaline. Then start on the driveline...Whether an auto or stick, It will be screaming for something to be done...
Bottom end isn't there with the ADR alone. Stack the smarty and hang on. I also lost 5 tenths at the dragtrip by taking the smarty off and running the adrenaline alone. Adrenaline is a hard hitter, just doesn't come on off idle like the smarty does.
I would get a fully built tranny to.
With the set-up listed he gonna get the most of of that pump with out tapping the wire. If he wants more latter, hes gonna need to tap the wire.
1 - 11 of 11 Posts
