FRONT AXLE - 9 1/4 AA
AXLE DESCRIPTION
SPECIFICATION
Axle Ratio
3.73, 4.10, 4.56
Ring Gear Diameter
235 mm (9.25 in.)
Ring Gear Backlash
0.13 - 0.18 mm (0.005 - 0.007 in.)
Pinion Torque To Rotate - New Bearing
1.7 - 2.8 N·m (15 - 25 in. lbs.)
Pinion Torque To Rotate - Original Bearing
1.1 - 2.2 N·m (10 - 20 in. lbs.)
Total Torque To Rotate - New Bearing
3.4 - 5.6 N·m (30 - 50 in. lbs.)
Total Torque To Rotate - Original Bearing
2.8 - 5.1 N·m (25 - 45 in. lbs.)
Fill Level - From Bottom of Fill Hole
6 mm (1/4 in.) ± 6 mm (1/4 in.)
TORQUE DESCRIPTION
N·m
Ft. Lbs.
In. Lbs.
Fill Hole Plug
32
24
Differential Cover Bolts
40
30
Bearing Cap Bolts
85
63
Ring Gear Bolts
140
103
Axle Nut
356
263
Pinion Shaft Lock Bolt
52
38
Adjuster Lock Bolt
25
18
