Hey, I just installed BD exhaust brake with a BD TowLoc box. Everything seems to work fine, I have the ex-brake on with the torq lock setting and everything calibrated as per the manual. My question is, do you drive in the torq loc setting or turn it on at speed you driving? When it's on, it will shift 1st, 2nd(then lockup in 2nd), then compound shift to 3rd! Is this normal (compound shifts)? One of the settings is for down shift from OD to 3rd, is this for when your climbing a hill or going down? If anyone is running one, could you chime in on what your settings are set at? Any info on how to use and setup this box would greatly be appriciated. Thanks
