make sure the set screws are removed... i just did mine easy as hell to do ...hmm
I did, not the issue. This thing won't even start into the bearing, it's to big.make sure the set screws are removed... i just did mine easy as hell to do ...hmm
Thanks I did see that when I ordered it from Geno's. My truck is an 06' though so it shouldn't be an issue. I got out my caliper today and measured the ID of the bearing and the OD of the shaft nut. Both are exactly the same so obviously it wouldn't work. Hopefully this new one is the ticket.BD STEERING BOX STABILIZER - 4WD ONLY ('03-'07) DODGE-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
Is this the part ?stering box stabilozer the note is in bold at the bottom.
If not sorry.
They both measured 1".What is the diameter measurement of the shaft, and what is the diameter measurement of the bearing race? I'm just curious...
