1 - 2 of 2 Posts
Description: 500 degrees Fahrenheit... That's enough heat to cook a five-pound chicken in 45 minutes. It's also the temperature of the air going into your stock intercooler. Compressed air is heated air and when you combine an aggressive fuel curve with elevated boost levels, that can lead to convection oven levels of inlet temperature.
That's why BD developed the new Cool-It intercooler. With 57% more cooling surface area and a 33% thicker core (2.625" versus 2"), the Cool-It increases cooling efficiency to approximately 90%, compared to only 70% for the stock intercooler. That can mean a temperature reduction of up to 200 degrees Fahrenheit over the stock intercooler. At the same time, the 36% larger inlet and discharge tubes (3.125" versus 2.625")can handle up to 100 psi of boost and over 1500 cfm, while holding pressure drop to less than 1 psi.
Increased air flow, reduced air temperature, lowerEGT's and higher HP, that's what you can expect from BD's new Cool-It intercooler. All kits come complete with high-pressure hoses and clamps, and are ready for shipment. Call us today to find a dealer near you!
Keywords: bd power intercooler
I really enjoy this addition. with my low amount of modifications currently to the truck it still helps out when under boost. seems to keep everything atleast 100 degrees cooler and turbo is even easier to spool. very pleased with the product. Kit included 2 new boot clamps and intercooler for 94-98 12 Valve.
Rating9
ProsLower EGTs, helps air flow, more hp
Consdoes not come with intercooler boots
Would you recommend?yes
1 - 2 of 2 Posts
