hey guys, so after two holley gerotor pumps takin' a poop, I decided to try something different. I picked up one of BD Diesel's bypass lift pump kits ( not the MAX FLOW). well the pump builds around 11psi when i hook it straight to the battery, but when I start the truck, the pressure slowly creeps down to Zero!!!. There is no way I should have 0psi at idle, even if it does use the carter pump. What could the problem be? I know everything is installed correctly. I'm starting to get seriously frustrated with this whole lift pump thing:banghead: Any advise guys? (besides that I shoulda bought an AirDog:lol4
