1 - 20 of 30 Posts
hey there I'm dealing with arcing when placing my battery cable back on the battery after putting om the new alternator and after deleting the plug on the back i got single wire alternator on the way any help would be awesome
· Super Moderator
Are you putting the correct cable on the alternator post?
One in the harness is a positive and one is a ground, did you mix them up?
Reactions: mattswaggs
· Super Moderator
Can you post a picture of the back of the alternator?
What kind of a single wire alternator did you get?
· Super Moderator
· Super Moderator
The old one could be shorted out for the reason it's arcing.
· Super Moderator
I would ground it just like the Factory one is, you can never have to many grounds.
Reactions: hpitt74985_1181
· Super Moderator
Is that a snake hanging down from the front plow mount under the G on the plate?
· Super Moderator
What is a fusible link alternator?
· Super Moderator
its the green fusible link in the truck that came stock
Maybe someone else will have a answer to that, I don't recall my old 92 having that.
Cut or burnt?
It may have burnt due to a short in the charging circuit. If so, you can replace it and it will burn again.
Need to find out why you're having arcing problems.
1 - 20 of 30 Posts
