So I've got a few add-ons to my truck - like most of us do...
The latest addition is going to be a combination voltmeter/ ammeter. I'll be adding more later and want to keep track of how much current I'm drawing. A push button switches between the two functions.
Connecting the voltmeter is easy..Common to ground and + to -duh - the positive terminal....
Now the fun :
I want to be able to read total current - except the starter...
The positive terminal looks like the thumbnail.
The BIG RED wire is obviously going to the starter. I can't find the others...
There are two black fusible links coming off the tightening bolt, the other red wires are my additions. Also coming out of the end of the terminal on the right side of the pic are a red wire, a black wire with a connector ( on the right side about the middle - I almost cut it off ) and toward the bottom just a little left of the corner is another connector that that has a red and black wire ...
On top of the batt is the 200 amp shunt I'll be connecting in series with ALL the wires except the red to the starter...
I think the larger black wire with the connector goes to the alternator, at least the 3 diagrams I've found that refer to the battery show the red to the starter and a black wire to the alternator.
Any help identifying the others ???
