21 - 40 of 278 Posts
I can think of 0 diff failures due to over heating of a properly setup rear end.
And therein lies the problem. We have AAM axles, not necessarily properly set up axles.
I couldn't care less what the covers look like, but if one can improve the odds of my AAM axles living a longer life, I'm all for it.
Then again, I'm one of those dummies who change the diff fluid at 500 to 1,500 miles, too.
Reactions: 007Poke
Changed my diff oil less than 2,000 miles as well. Wanted to get the Royal Purple in there plus wanted the magnetic properties of the new set up.
Reactions: lzhome and Jimmy N.
Anyone who doesnt know by now that Banks is going to jump in the differential cover bandwagon doesnt understand how marketing rules the consumer world. Gale Banks would not bother making a video showing how he's "learning" about differential covers if he isnt planning on presenting his newly designed (and better than everything else out there) differential cover in part 2. It only makes sense... :thumbup:
Yep. And the key words here are "better than everything else". Not holds more fluid, or has more cooling fins, or looks nicer.
When Gale puts out a product it works as well as practicable.
It's a differential, who gives a $hit, If the diff cover wasn't visible, this thread wouldn't exist. Got to love marketing.
I've got 99 problems, but a diff ain't one.
Yep. Aside from doing something like jumping the truck under hard throttle, then landing back on a hard surface, differentials are almost indestructible.
GAmes in the 2nd gen section has 1,300,000+ miles on his truck. He replaced the first engine at around 800,000 miles, has been through 3 or 4 transmissions at least, and countless other things, but the one thing he's never touched is the rear diff.
Reactions: Sliver CTD
I grew up in the muscle car era. A time when people were eager to take a perfectly good car and turn it into something loud and uncomfortable and obnoxious to its surroundings. Something worthy of the cruise... Your options on products were somewhat available but also limited to what you were working on and what you were after, so heavily customizing was usually much a part of the process.
Banks was making himself back then too and doing some pretty cool things. Always in the magazines. But all these years later I now look at Banks as a business man. His company still builds wild examples of performance and puts them out there to keep the Banks name synonymous with performance...but seemingly stopped catering to the wildly hardcore crowd looking for insanity over practicality. Rather Banks looks to satisfy the majority of consumers who want marketable gains but more importantly practicality and bling. The people who prefer plug and play and preset packages so that there's no messing and guessing, just bolt on and go.
I'm not disrespecting Gail Banks and his company either but merely making the correlation that if I see someone's truck with all kinds of red products under the hood I already know what kinda power its putting to the ground simply based on the highly visible and heavily advertised goodies. (and usually the defining "Banks" sticker somewhere on the side) Some are decent, some are just there to look better than OEM.
But under the hood of a truck with strange and sometimes unrecognizable items assembled by the owner who chose their concoction based on what worked and what the combination achieved... Those are the trucks that you know are serious. Not always, but generally.
So that said..... Will Banks new differential covers be any better than whats out there? I'm not sure but likely not. I'm sure he'll be reaching for something a little different and a little more niche so that he lures in the consumers who believe Banks stuff is always proven. And thats OK too... :thumbup:
Reactions: nick00less
That cracked me up, KATOOM. Just replace "muscle car" with "diesel pickup", and "perfectly good car" with "perfectly good pickup" and you just described what many Ram owners are doing.
Agreed, I did mine for the ease of future maintenance and looks. If it lowers it a few degrees that’s a bonus if not I’m not worried. It also has extra magnet on the dipstick which certainly can’t hurt. Mag-Hytec makes a very solid well made product.
Also, Gale Banks is a great product marketer. He probably has a new product coming out and this is part of the campaign. Get people talking and let it simmer a while then come out with a “solution”. The solution will probably come out in video part 2. No other reason not to just give the result in the first video. Take like 30 mins to do the test.
Same cover on the rear of my '17. Banks may be a helluva guy, and I know he makes a helluva product, I mean, because all of his in-house tests prove it. LOL. Honestly, I don't see very many other vendors bashing their competition like Gayle Banks does. ;-)
It is possible cooling the lubricant isn't the best idea given that lubricants are designed to lubricate at certain temperatures. Temperature is critical to the performance and life expectancy of lubricants, cooling can be as bad as overheating.
True, but I don't think ANY diff cover available will be able to cool too much.
True...I'm pretty sure we all can agree on that. Though the rear axle (both axles actually) on my '06 2500 with Mag-Hytec cover never saw any temps above 210 degrees no matter what I was doing. Had ISSPRO gauges on f axle, G56, TC and r axle. And I live in the desert southwest where temps can be 120+ and pull a trailer/tractor quite regularly. Just my personal experience FWIW. ;-)
No differential cover will cool the fluid too much and cause a lubrication issue... And in saying that, the only method of offsetting arctic temperatures is to run the appropriate viscosity lubricant for whatever those conditions may be. No one should be running 75-140 where it gets well below 0*. :thumbup:
Reactions: jeepmanjr
I do. But even if it's 20 below, the trip starts from within a heated garage.
Well, latest video is out...
https://youtu.be/0PMvVcsU3PE
I can't wait for some on here to tell me it is more fake data by Banks!
Sent from my moto g(6) using Tapatalk
Well I'll be the first to jump off the ledge...so pause with the pitch forks and torches and hear me out.
My opinion is, I am very disappointed in Gales "technical" assessments of aftermarket differential covers in his latest video. That being Mag Hytec since no others were even mentioned. Actually I thought his "testing" was incredibly incomplete as he threw out a lot of speculation and conjecture with no data to support any of it other than a see through view.
First off, Mag Hytec does NOT specify in their directions to overfill. The added capacity Gales referring to is because of the extra room the aftermarket covers can offer. So for him to throw MH under the bus I felt was bad ethics...
Also, maybe he forgot that in his last video with the plastic curved cover we got to see how the fluid moved about. And if you watch both videos back to back / side by side, you can see that the fluids in both covers do the EXACT same thing. It moves about the same, it aerates the same, and it sloshes about the same. Well actually I thought the MH cover didnt aerate as much as the curved cover.
The only real difference I noticed is the round cover didnt have any mood lighting. Not to mention that he started the MH cover test ideo with much slower speeds to show the sloshing, whereby he didnt do that in the curved cover video.
All that said, (and I dont mean to seem like I'm picking on Gale) the one thing he clearly didnt test, which is the main reason for adding an aftermarket diff cover (next to bling factor) is any reduction of fluid temperatures through capacity and dissipation. He also didnt bother to offer any testing on the resistance of fluid "work" which he claims is taking place by the fluid hitting any flat surfaces.
So...point being, I think Gale better step up the testing with some good solid results showing heat comparisons and fluid resistance comparisons. All of which cant be refuted in any way either, otherwise this is one big waste of time. :thumbup:
My opinion is, I am very disappointed in Gales "technical" assessments of the aftermarket differential covers in his latest video. That being Mag Hytec since no others were even mentioned. Actually I thought "testing" was incredibly incomplete as he threw out a lot of speculation and conjecture with no data to support any of it.
First off, Mag Hytec does NOT specify in their direction to overfill. The added capacity Gales referring to is because of the extra room the aftermarket covers can offer. So for him to throw MH under the bus I felt was bad ethics...
Also, maybe he forgot that his last video with the plastic curved cover we got to see how the fluid moved about. And if you watch both videos back to back you can see that the fluids in both covers do the EXACT same thing. It moves about the same, it aerates the same, and it sloshes about the same. Well actually I thought the MH cover didnt aerate as much as the covered cover. The only real difference I noticed is the round cover didnt have any mood lighting. Not to mention that he started the MH cover video with slower speeds to show the sloshing, whereby he didnt do that in the curved cover video.
All that said, (and I dont mean to seem like I'm picking on Gale) the one thing he clearly didnt test, which is the main reason for adding an aftermarket diff cover (next to bling factor) is any reduction of fluid temperatures through capacity and dissipation. He also didnt bother to offer and testing on the resistance of fluid "work" he claims is taking place by fluid hitting flat surfaces.
You must not have watched video part 1&2 yet...this is video 2.2 or 2.3...don't remember what he said, data is coming in future video...no doubt he is playing this for all it is worth, but the data won't lie. I personally think the best cover is the AAM finned cover....shipped directly to my front door for less $100 with new reusable gasket and fasteners...
Can you post a link for the AAM cover for 100.00 please?
Reactions: BrianF
I bought mine a couple of years ago, but Drivetrain America shows it on back order, I will pull the Mopar PN off of the box tomorrow. Quirk Parts or Tasca is where I got it from.
Sounds like someone is mad they spent money on a cover that you thought was superior but turns out hinders performance...
R.K.
