👋 Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
2013-2018 4th Gen Ram 6.7L Cummins
Late 4th Gen Trucks- All with DEF
2010-2012 4th Gen Ram 6.7L Cummins
Early 4th Gen Trucks- Non DEF Pickups
2007.5-2009 3rd Gen Dodge 6.7L Cummins
DPF Equipped 6.7s
2003-2007.0 3rd Gen Dodge 5.9L Cummins
The High Pressure Common Rail 5.9s
1998.5-2002 2nd Gen Dodge 5.9L 24V Cummins
The VP44 5.9s
1994-1998.0 2nd Gen Dodge 5.9L 12V Cummins
The P7100 5.9s
1989-1993 1st Gen Dodge 5.9L 12V Cummins
VE pump 5.9s
Other Non-Dodge/Ram Cummins Applications
If your Cummins is in an HD truck, RV, Boat, etc, then this is your section!
Conversions - ShopTalk - Tools&Boxes - Fabrication
NO ADVERTISING
Discussion of the Cummins Conversions and Fabrication Needed to Complete. Talk about and show off your Tools - Tool Boxes & Shops. Show off your General Fabrication Projects
General Forums
Specialty Forums
Technical Articles - Writeups - Guides Section
Forum Resources
Marketplace
Member for at least 10 days with a minimum of 20 posts required to access
Vendor Member Section
Want to Grow Your Business? Learn more about becoming a Supporting or Premium Vendor
Regional Forums
Forum Support
Community Hall
Latest Posts
Good morning everyone! I have a 1998 12 valve with a 47RE transmission. I’m looking to do a G56 swap but have been struggling to find what I need to do with the wiring to bypass the neutral safety switch to start the tuck. If possible I would like to eliminate any check engine lights and would...1 reply 112 views
I know it’s been asked a million times but I’d like to hear opinions on exhaust housing sizing Truck is an 01’ 6 speed. I’m going to be dropping it off at industrial injection in about a month for a built/balanced motor ported head, p7100 swap and compounds. Timing will probably be around 24°...2 replies 82 views
Hoping someone can guide me in the right direction to this issue. I have an 09 6.7 with the 68rfe transmission. Purchased the truck about 5 months ago first day I got it randomly shifted into 4th from 6th gear. Thought it was just a fluke thing until about a month ago it happened again. Since...0 replies 20 views
Howdy folks it’s been a while since I’ve posted, I’m curious how much should a transmission rebuild cost in 2024, as well as having a transfer case resealed. I’m out west here in the pnw specifically Oregon.14 replies 246 views
Hey guys, this is my first post so hopefully I'm approaching this right. Today I took my (new to me) truck through an automatic car wash (probably my first mistake) and the check engine light turned on in the middle of it. I'm assuming the undercarriage wash hit something and caused all these...3 replies 98 views
