1985 D-350 Crew Cab w/ 89 12V 4x4 swap, 315hp marine ppump, 370 injectors, BW k27, G360
To start I have searched to forums and tested a few things.
Right now everything in the truck functions except starting with the key. The wiring is all from the 1985 D350 with a transplanted 89 Cummins. Ran awesome until I went to leave a car show turn the key everything turned on, turned to start and nothing. So quick trouble shooting at the show and I just jumped the wire at the starting relay (so I didn't have to crawl under the truck with a screwdriver). The starting relay ground pin is hardwired to ground thus removing the neutral safety switch. If it matter this truck is a manual swap as well.
I tested the relay at home by jumping 12v straight to the ignition wire on the relay = truck fired right up.
I tested the plug under the dash by jumping the 12v to the ignition switch to the signal wire that leads to the relay = truck fired up again
Replaces the ignition switch and have the same problem, turn the key to start and nothing. So I jumped the connections at the back of the switch directly and the truck fired to life.
Anyone have an idea why two ignition switches would not send the ignition signal to the starter relay? Does the ignition switch somehow act like a relay/solenoid?
