i found out that it was leaking out of #2...i took the injector and tube out to inspect for any kind of damage. everything looked good, however the tube was covered with fuel which makes me think the line wasnt seated properly in the tube. one thing i noticed, when i was taking the threaded part out of the head, it was difficult to remove. however, when i put everything back together it threaded almost all the way with my fingers, then a couple turns of the wrench tightened it up real well. so i dont think the threads are damaged.
i was talking with a friend who had this problem when he installed SS injector lines. he clamped the lines down before threading them into the head, and that put pressure on the seat (end) of the injector line causing it to elongate. therefore, the line wouldnt seat properly in the tube. if that is the case, #2 line from cummins is $80.
i also checked the oring on the tube and it SEEMED okay, but i am going to replace that first incase that oring is actually damaged.
let me hear your thoughts...sorry for the long post
