the truck idles rough i replaced the rail pressure sensor and the fuel module.. the trucks rail pressure goes from 5100 up to 5900 without touching anything and put outs a lot of white smoke it popes and sounds like timing is off and is misfiring.. could a bad ecm do this i had a battery terminal melt down not to long ago and now I'm having this
Bad ECM could have an effect, you could try and have it flashed/updated before you assume it's bad. Also if you haven't had the valves checked, they may need adjustment. Valves should be adjusted at 100K. The white smoke almost sounds like a bad injector or excessive blow by, but start with re-flashing ECM, then valves, then if nothing else resort to injectors after you check blow by.
ANY codes.
2nd bad injector or so. It will cause the white smoke and rail pressure fluctuations.
If your getting codes then maybe sensor related.
Discussion Starter · #4 · (Edited)
Could a bad ecm cause the set rail pressures to fluctuate all over the place?
Were using a snap-on reader and watching the set rail pressure fluctuate all over the place. When we hooked the same reader into a 04 cummins it didnt fluctuate at all it stayed at 5380?
I've never had a good enough scanner to read set rail pressure but I still would think injectors unless you had codes and or intermittent power.
The white smoke is what does it for me.
What terminal melted, why and what was the fix?
Well it does have the intermmitent power it misses and pops..
The terminal i believe was a bad battery i replaced the terminal that melted and replaced the battery and havent had a problem since
