1 - 4 of 4 Posts
A question biodiesel machines that are out there.When you are finished with the process...Do you have only B100 ?
Is there a process to make B5 and B20?
Is it as easy as just mixing Ulsd fuel to it in precentages ? Are there problems with mixing ?
Thanks as Always Bill
You get B100(pure biodiesel) and then you can blend it with whatever. Its not like ethanol, when you must run a certian blend or things go screwey. You can blend at whatever level you like(mostly depended upon weather).
thats it if you want to run B20 make a 40 gallon batch of biodiesel (which will be B100) and mix that 40 gal with 160 gal of pump petro diesel to get 200 gal of B20
or 40 gal of pump diesel to get B50...........you get it.........
1 - 4 of 4 Posts
