Ok I’m getting my butt kicked, I’m about to lose my mind from frustration and stress.
So I installed [email protected] hitch 1313 for my 03 Dodge Ram 2500. Install went pretty well. I had the bed off cause I was prepping my rear frame for undercoating. I got that done And moved on to the hitch. Install went pretty good at lest I thought. The u-bolt that sets against the frame on the inside and pulls the bracket tight against the frame bent. The instructions say to torque the u-blots to 60 ft. I got my snap on torque wrench, not a cheap Chinese knock off. And set it to 60 ft. The torque wrench never clicked. It just kept going and going. I knew something was wrong. I looked closer and the bracket the u-blot Connects to was bending. The u-blot pulled so hard it put marks on the bottom and top part of the frame.
I called b&w and asked if that was normal. The guy says yes the bracket is supposed to bend and conform to the frame. And he said the u-blot would snap before it started to dent the frame. He said to but it back on and keep tightening it until the torque wrench clicks.
I don’t know if I’m comfortable with that. Passenger side was trying to do the same thing but I just got it good and tight and left it. Has anyone ever had this problem? I really don’t know what to do I’m so frustrated.
Sent from my iPad using Tapatalk
