It will just come out, be carefull there is a seal in there when you put it back in hold the shaft up so you dont damage the seal. Look in there before you put it back in and you will see.I'm gonna be replacing some u joints tomorrow and I haven't found a good write up on this topic. For the axle joints, once I get the hub assembly off will the shaft just slide out or is it necessary to drain the diff and remove the axle seal? I've read conflicting directions.
