1 - 3 of 3 Posts
Ok so i dont know much about whats inside the front axle but i know theres a bearing and seal in there somewhere. I am replacing the front u joint and wheel bearing and so i pulled the front driverside axle out of my 2004 dodge ram 2500 4x4. i was wondering if since i pulled it out will i need to replace that seal inside there. is there a trick to putting the axle back in to not hurt the seal? Thanks guys you all have helped a ton. i am new and learning this stuff thanks a ton
Um not that I know of. Just be gentle with her. And it wouldn't hurt to replace it either. But if its not showing any signs of leakage then leave it alone.
1 - 3 of 3 Posts
