1 - 17 of 17 Posts
Any ideas? I measured from frame to wheel on both sides and the tape 3/4" difference.
I jacked up the back end today and loss end the u bolts hoping there might be a little play where I could pull the axle over to the driver side but I had no luck.
· Banned
Oh! Side-to-side. I pictured one side being forward more than the other...
I'd take it to the dealer and say "fix it." It's not right. Did you hit anything?
They are all like that from the factory. Something to do with torque.
Adjustable Trac bar problem solved
Couldnt find anything. Made sure u-bolts were torqued and hadn't moved and spring mount bolts/bushings looked good. Nothing bent.
1 - 17 of 17 Posts
