anyone know where i can get the collar that locks the 2 passenger side axles together? also where i can get a new inner axle? thanks
Discussion Starter #2
btt?????????
scrapyard....?
If your looking for new parts, they are readily available from most parts stores/driveline shops. They are actually not that badly priced, i did mine a few years back after shredding a shaft, ran me about $700 for everything from the carrier out to the wheel (3 new shafts and the collar)
If you only need the inner and a collar, it should be under $200 for the new parts. IIRC it was about $500 for the outer shafts when i got mine :shock:
what is iirc? dave if you got time can you give me a shout this afternoon. say 11ish? i would greatly appreciate it. im headed to work and wont be about to look on here till tonight so maybe if you called i could write this crap down and call about it while im at work, thanks. 817-760-131four robert
IIRC = If I Remember Correctly
You can get all the parts you need from Quad4x4 Dodge Front Axle & Steering
Inner axle, collar and inner axle bearing set $242.61 w/o shipping.
got inner axle, and the collar overnighted from the dealership for 340. i know it was a little much, but not bad for the dealer.
