1 - 10 of 10 Posts
Just picked up a trans temp gauge and was wondering if any one has one.
Also will the sensor fit into the test port of the tranny?
If not where did you put it?
What adapters will I need Thanks
if you want the most accurate reading of the actual transmission fluid temperature then you need to install the probe in a tee on the hot return line
I installed mine last weekend and I drilled and tapped the pan with a 1/8 NPT tap. Was really quite simple. Once I was done though I noticed that it looked like there was a port I could have used, but I am glad I did it this way, now I have a way of draining that pan before I drop it and wear ATF!!:thumbsup:
ya can do it on the sida the pan and be ok:D
just watch out where ya do it, DON'T drill below a pan bolt....:doh:
I know there is a test port on the side of the trans and i was wondering if ant one put it there and if the autometer sensor fits right in there or if i need adapters.
jes go out and give it a try yerself man:D
This question has been beat to death and I havent been able to get a decent answer. Lemme SEARCH for a thread that had some decent info and Ill post it up.
1 - 10 of 10 Posts
