Ok so my trans cooler lines were leaking again and i decided to remove them and replace them with Hyd Lines. After i removed the old lines, i decided to pull the brass fitting in the trans. With my luck the fitting snapped off with little force. I was able to remove it with a easy-out. My big problem i now have is the case around the threads is cracked. I tried my best to seal it but nothing is holding. I bought a couple different items and they did not work. I try JB Welding the outside and that didn't hold, so i JB welded the inside with the fitting and it still leaked. Not sure if the weather is causing the JB Weld not to cure its been a high of 30 and been a real pain to work on the truck. So here are some ideas:
1. weld the crack.
2. Cut the crack and threads off and re drill and tap.
3. Recase the trans.
4. Swap my auto to manual
5. or theres a fitting that is supposed to fix it. http://www.sonnax.com/system/instructions/22000-01_01K-IN.pdf
Its hard to tell but if you look at the second picture you can see the crack starts on the left and go's through the threads around the bottom and back up the other side.
1. weld the crack.
