Today I received my ARP 425 Headstuds in the mail. Im sick of babying my truck and I want to get these things on ASAP. Im gonna do it without removing the head because my headgasket is fine (one bolt out, one stud in at a time method). There is supposed to 6 long studs for the exhaust manifold side and 20 shorter studs for under the valve cover. Well in my box I have 7 studs that are the longer exhaust manifold length and 19 that are the shorter length for the studs that go in the valve cover
(should be 6 long studs, 20 short studs). Since they are all the same size other than length, can i just throw that extra 7th longer stud under the valve cover and be fine? Or do I have to wait longer and send these back to XDP and wait to get ones with the correct number of bolts.
Im guessing it will just be fine to use that 7th longer stud under the valve cover, as long as it clears rocker arms and such.
I got lucky with some 55psi high boost runs on stock headbolts (not sure how I pulled that off, but I did) but dont wanna take another chance lol
