1 - 12 of 12 Posts
K
Guest
i know a few people with one and they havent had any problems and i just ordered one for my truck
cumminsforum.com
Mule Barn Proprietor
I'm using one with no problems at all. Been on about a month now. Super easy install, great instructions come with it, and there is no way you will beat the price. Its a quality piece.
Josh
K
Guest
i just got my timbo apps in the mail i dont have a digital voltmeter to test to see what the voltage is. do you have to do this step or would it be best to. i can wait to put it on till i borrow a voltmeter.
Put it on. Check it and adjust when you get your hands on a voltmeter.
K
Guest
alright thanks i dont drive this truck much its just my toy i should be able to check it next weekend at a friends
cumminsforum.com
K
Guest
yeah it works great no problems i just wasnt sure if it matter if i checked the voltage or not since its in the instructions and says to adjust the set srew if its to high
Funny part is it would work just fine...
Yep, it will work just fine. MAY have a little "slack" till the throttle starts responding till you adjust it. (If it even needs adjusting). Mine did, 1/4 turn on the idle screw took it right out.
K
Guest
it seems perfect no slack or anything but im still gonna check it to see where its at ill prolly just stop by a friends on the way to cordova il for the nhdra race next sat then might run then truck see how it does but i need to borrow something for boost fooling but my guess it will be slow since its a 6speed
1 - 12 of 12 Posts
