1 - 9 of 9 Posts
Has anyone tried one of these to use as an intercooler boots and if so did it work?
Reducer Elbow
I have a kit from Haisleys on mine, the only thing I would be worried about with those would be the working pressure at 50psi. Seems a little borderline for me although the burst pressure is at 200. No personal experience with them so I could be proven wrong.
yeah, i had a boost leak so i bought a full kit. the passanger side is on, but im waitin my turbos to do the driver side.
they fit great, didnt have to tweek them at all. they are alot thicker than stock for sure. the clamps fit a little tight, so you have to squeeze them a little with channel locks to start the nut.
Prob not but i already had the kit so i figured why not it helps with egts while towing and it seems to help the turbos spool a little quicker, and gives you a little more go. So as for the boots you ordered the same ones i posted then? The 4-3.5? just wana make sure they are the right ones
1 - 9 of 9 Posts
