1 - 2 of 2 Posts
Was looking at another thread on cost to repair KDP, one gentlemen said to ask for help from a local on here so I figured I’d give it a shot. Anyone near Cleveland, TX? 93 5.9
For your year, the case bolts are not coated with sealer so they can come loose and fall onto the gears. You can remove 4 by positioning the cam gear windows. The fifth can be tightened with an offset open end wrench. You can also R&R the two holding the cam. Use blue loctite. The KDP can come out, but is less common to happen than with the P7100 which causes more vibration.
1 - 2 of 2 Posts
