1 - 3 of 3 Posts
I have a 2012 RAM with a 5' RC lift with and adjustable track bar. I want to double check its at factory length (centered) from bolt eyelet to eyelet. I adjusted it based on the stock track bar before I put it on, but just want to double check it after the lift has been on for a couple months.
Thanks again
Thanks again
It would need to be longer than stock to compensate for your lift height in order to re-center your axle. I think for a 3 inch lift my Carli bar was at 39 1/8 eye to eye.
Well Actually the Rough Country 5' Drop Bracket is designed to keep your truck as close to factory geometry a possible. I did a Measure before re-adjusting and it was 39 1/8, about 1/4 inch or so to far to the left (Drivers side), I measure the eyelet to eyelet of the stock track bar and it measured 38 3/4s, re-adjusted the new track bar accordingly and my front axle is now dead center. In fact I have less tendency to need to over correct as I'm driving straight despite the slop that comes on the gear boxes of these trucks.. :)
1 - 3 of 3 Posts
