1 - 10 of 10 Posts
Hey guys,
Just wondering if anyone has done this. Did you get the stick tested after you did it? I see you can buy the tool online for $20 but is it worth the time to even try it yourself? Is it something that is easier than it sounds to do? Please chime in with experience as I look forward to hearing both sides. Thanks in advance.
I didnt test mine when i did them. It was pretty easy and i didnt know anything about injectors and it only took me about seven hours and had no problems at the end.
its very easy to do...the tool make its easier to remove the tips. the actual process of changing tips should only take 30-45 min at most. but getting to an putting everthing back together takes a little while.
Who sells the tool?
Northern CA Chapter President
ive done it twice, it takes me about 3.5-4 hours :thumbsup:
Do you put the injector in the tool and then turn it to twist it off? How does this work? Never seen one.
Discussion Starter #8
Anyone ever use this tool?
ddp will loan you a tool you give them $1200 and when you return the old nozzles and tool they refund $400. instruction booklet with it. take your time and keep it clean, as stated the first time will be about 6 hours the second one you do will be 3-4 hours, make sure you have a torque wrench
Discussion Starter #10
Thanks guys! I will keep you posted on how it goes.
1 - 10 of 10 Posts
