I guess I'm just worried about dropping $$ on a turbo that I won't be happy with. I'm not sure if a 65 would be too small and a 71 would be too big?
Care to elaborate a little more? Have you run one? :confused013:the 62/68 will surge during heavy towing..
That's what I'm thinking :agree2:I've heard great things from guys running the 62/68....that turbo shouldnt surge. turbos usually surge when the compressor and exducer wheels are close in size such as a 64/65
Quick spooling but a little on the hot side with a 12cm housing, the 14cm housing would be a better match for 150's.how would a 62/65/12 run off 150's?
im just thinking for twins later on...
but for twins i would think u want more like 200-250 injectors correct?
Unless you are planning on running 150 or larger injectors don't go any bigger than a 64, all you will get with anything larger than a 64 is alot of smoke trying to get up to speed as you will not have enoug fuel to spool it up quick enough. what mods do you have? i am running a 64 and drive it everyday.
Are you saying that you run a 64 in the top post and a 62 in the second post? You sure can change a turbo fast...what mods do you have done? I'm running a 62, unless you are going to run 100hp injectors or bigger 64 is not going ot help, just going to make alot of smoke. let me know what you are looking to get out of the turbo you want to buy.
