The 47Rh is a hydraulic trans in the 1st three gears. The PCM controlls OD and converter lockup.
Check the setting of your throttle position sensor.
TPS testing and adjustment
If your upshifting into 3rd below 20 MPH I would adjust the throttle valve cable also. I couldn't find a write up for a 2nd gen on how to adjust it. I hope one of the 2nd gen guy's steps in for that.
