1 - 20 of 81 Posts
guys im a diesel tech at planet dodge in humble texas i can give you answers or advice if i dont know i can look it up for you so pm me or for emergency situation give me a call 979 618 1144 just love my job and want to try to help
thanks
grant
Grant,
Any truth to the rumor of a June Flash for the 6.7? thanks
hey yes it is coming man they also have a kit for 2262 turbo code
Good to have you aboard. I am sure I will be pestering you for information.
Not as of yet, but i am looking to have some more parts "fall" off the truck :thumbsup So far i love this thing.
no problems here ... there was some mention a few days ago about a June flash that might improve mileage ...
yea its my pleasure the ppl on this forum are great thats why i give my number good ppl and you never know im a diesel tech but i may need help from yall so ask away guys i promise to you i will get you an answer guaranteed.
Do you know of anyway of disabling the EGR? Also do you have any Turbo Specs?
See, ya got me started already. LOL!
no? I dont. Not sure the dealer around me would care to much to work on my truck
Discussion Starter · #13 ·
i can get the specs the actuator and the valve will throw a code if unpluged and or defuel or detune the engine
well i have the one side unplugged already. It does throw a code but no derating. Though i am wanting to remove the cooler on the other side. It has another valve as well as the pressure sensors in the Exhaust manifold.
Discussion Starter · #15 ·
with the vgts and or vnt turbo they can see boost right off the bat thats whats so awsome but they are cut back cause of the dealer but i will get you a reading tommorow on "stock" boost
Discussion Starter · #16 ·
yea the cooler is a good idea just block your coolant lines off get you a blocking plate for the egr cooler in port and just block the in port of the egr valve
thanks for offering your help, that's awesome. I'll be watching closely to see what kind of advancements you can help some of our more adventurous members make. thanks again
What is that back pressure line for? if its removed what could it hurt?
G
Hey Grant. I got kind of a simple question. I have gutted the stock intake tube, and have an afe drop in filter on order. I've read since doing this, that the baffle in the tube actually helps to get the air to the turbo correctly and that removing it could be bad. What do you say? I honestly think since I gutted it, I'm getting a little better mpg, and I hope the less restrictive filter will make it even a little better.
1 - 20 of 81 Posts
