Got it! and 1R-0750 is the filter correct??Better Filtering (microns) with the CAT vs the Fleetguard.
Yup. You just remove the o-ring from the filter base.
Thanks brotha!!Yup. You just remove the o-ring from the filter base.
Dammm this kit looks good to!Anyone using this kit on a 4th gen? Any issues with fuel pressure drop or anything else? Winter issues?
Looks real appealing to me, been thinking about it for a while.
The BEST Dodge Cummins Fuel Filter Kit Available
Im running my AD165 through the CAT filters on a GDP setup. Fuel pressure reading is between the filter head and the CP3. I have never seen an instance where the CP3 was lacking fuel pressure. A constant 14-16 psi is seen across all MM settings and driving habits.Thanks i wanted to make sure it would fit on the stock truck.
With the advise/help of you guys i just ordered the Kit. Figure its alot cheaper then a cp3 or injectors in the long run.
Later on if i get spare money and i plan to upgrade the power more how much will this filter flow or support about how much hp ?
Cause I know with a mini max on hot dam it will be limited by fuel flow stock
