1 - 20 of 29 Posts
I searched but not much stuff came up just wondering whats going on in the world of upgraded VGT turbos?
I still really wanna upgrade to get more boost but dont want compounds, and don't want to lose my eb for towing... I live with that thing on lol. I know glacier was talking about a wildcat but never heard anything else about it... that or throwing a HE451ve? or was it the 551VE?
glacier has some out for beta now!
looks very promising i can't wait!
Industrial Injection has had some out for a while too, but they are not on the site. You have to call.
MOD-A-HAULIC
I have one .... works good...
Worth the $$$ .... I dont know.....
Have the EB but wish I had the bigger single ...
how much are these new from II,if you don't mind me asking??
and how big are the stage 2's.....62mm or 64??
Yeah I called them but the guy gave me the friggin run around then just tried to sell me a set of compounds, it was like pullin teeth to get him to tell me anything about it.
Exact same thing when I called! Really pushing the compounds.
seems like about everyone that has called them they have tried pressuring them into twins, i have heard several people say that:confused013:
There phone sales people does there company no justice at all.Every time i call for what ever i will get one answer,then call back on purpose just because i was not comfortable with the answer i got from the incompetent person i spoke with and guess what happened?Yep, i got a different answer.
This is where I am getting stuck at. I want TWINS but a bigger VGT Single would be just awesome. I guess it all depends on how much these "upgraded" VGT's cost over a set of twins. [email protected] decisions...........
in the end it wont be a big difference, and still with a single vgt , you will be limited, they push the twins for future upgrades, i too would like a biger vgt, but i know i wont always be happy with just that. so a bigger single will probably be the way for me. fyi , last i heard the single big vgt was around 2200-2400. twins arent far from that
Here's the description we got on the turbos from II:
On the Stage I Hybrid, Industrial Injection is replacing the factory compressor wheel with a larger 64mm compressor wheel in order to increase top end power / boost and lower EGT's (Exhaust Gas Temperature). The Stage II Hybrid also includes a 64mm compressor wheel, but then has the addition of a larger 71mm turbine wheel to assist in lowering drive pressure, which in turn will help relieve pressure on the head gasket.
Do you guys know what the stage 1 and 2 are running for boost. I still have my stock turbo and i'm fairly happy with it. It peaks at 44PSI and holds 40PSI. My Egts top out around 1480 degress. But I lack the quick spool ,do you guys thing the stage 2 turbo has that little extra on bottom end.
Discussion Starter · #17 ·
44psi? I max out at like 35 if I'm pushing her hard with smarty on 200... I thought the turbo map goes out of wack after 33 psi?
I can hit 43-44 PSI as well - but its not efficient or beneficial to get it that high. But VGT 4 on the Smarty makes it get up there.
Discussion Starter · #19 ·
mine is set at 4... but im on 14me still, I wonder if I need injectors, that and everything else is set at default on SW9
retune your truck , try sw6, hgt4, rp and timing default or timing 1, i run 14me and love it, imabout to try 18 just to play with the timing, maybe run on timing3 with the 18 software.
1 - 20 of 29 Posts
