I played with my after market key-fob trying to get the horn to honk when I locked and unlocked the doors and somehow set the anti theft system. The security light is blinking on the dash when the key is off and stops blinking when I turn the key on. I have tried pushing every combination on the key fob; disconnected the battery; touched the negative to positive; used the key to unlock both doors and held it for 1 minute; pulled the fuses it showed on line; turned the key on and pushed the trip meter button and cleared the dash lights. Nothing worked. After I used the key in the door, the key fob did work briefly to lock and unlock the doors but now nothing.
Any suggestions would be appreciated.
Thank you in advance.
903182
Mark
Are you sure you're in the right forum?? What year truck are you talking about?
Then you are, in fact, in the wrong forum. This is the 94-98 section.
You may have better luck asking owners of the same generation truck..
Ok. New to the forum. Thank you I will try again to get the right forum.
